NASTY surprise from Toro on filler plug
VirginiaIron
My unit has an Allen socket. Use a long Allen socket to tighten and break it loose. Use a long wobbly Allen extension to remove and install the plug, and of course a 24-36” socket extension.
Auto Doc's
I was going to mention using a die grinder with a burr bit to shape the hole accordingly.
Apparently, the engineers had a hangover when they drew up the diagrams for the stamping dies. The assembly folks did not have enough care to mention the problem, just like the QC folks.
