primerbulb120
Be careful when applying anti seize! Engine vibrations could cause the plug to come loose, draining the oil and seizing your engine. I learned this when I applied anti seize to a lawn tractor's blade nuts. After being used twice, one of the three blades fell off, one was about to fall off, and one was slightly loose.
