MZ54 Mower Deck
wv109323
I have a MZ 54 model number 96795370200. The machine has 237 hours on it. I have replaced a total of (3) idler pulleys P/N 532196106. Then the bolt p/n 588438301 broke on the other idler pulley. This bolt is threaded into a piece of 1/8" metal welded to the deck. The bolt is a 7/16 bolt. Is this common? This design looks poor and insufficient. To bet it all that bolt was impossible to remove. I was just wondering if others have experienced this problem and possible solutions?
Rust eats away at all of the deck component and eventually the deck shell. Sounds like you need to drill and extract the broken bolt portion so a new bolt can be installed. Most of the bolts a grade 8 high strength bolts, but they don't last forever.
