Foxxfuzz
Got an old murray riding mower. identification plate hard to read. original engine replaced with craftsman 12hp and battery out of miata. the rear frame was cut to fit engine. badging says 30 inch 10.5hp. motor fires, blade spins (after beating deck straight with hammer), but wont move. its quite a frankenstein beast. hasnt run in about a decade, but motor runs fine. drive belt system original. Just trying to figure out model to get belt, which can only be found by braille, and is missing. 1st pic is actual id plate. 2nd pick is closest i've found. Need model number to get parts. any info appreciated. [email protected]
