I had to remove the mower to do some repairs. When I got the mower started to use for something else it would not in either direction.
I am not a mechanic so I am not sure what the problem might b. There are three belts, one is under the battery compartment, guessing it is a transmission belt, there is a bel under that one which rungs to the upper pulley at the at the front of the mower and of course the is the mower belt. The top belt appears to be tight, other belt that runs forward is loose.
When I depress the clutch and shift into forward or backward, mower will, not move. What might I look for@
