jekjr
- Jan 3, 2013
- 271
- 1,969
Hello All,
A few months ago, I purchased a Cheetah. I haven't used it much as it only has 10.8 hours on it. I was mowing a few days ago and it started mis-firing and then quit.
I checked for fire: Good.
I checked for fuel: Good.
I checked the air filter: Good.
I put a squirt of fuel in the carb and spun the starter: NO GOOD!!!
So, with nothing else left to do, I pulled the plugs and they looked awful. Dark black everywhere.
I put new plugs in and it took off running great.
So, I visited the local shop that I purchased the Cheetah at and the only idea that they could come up with was that since my back one acre is very bumpy, maybe I was bouncing the carburetor float around and the fuel/air ratio was pooched. I don't know about that one. Also, I typically run it at full throttle.
Any ideas?
Thanks,
John
Did you over fill it with fuel? That might possibly be your problem if you did. You only fill it to the bottom of the white inserts in the tanks NOT TO THE TOP. If you do it will cause you problems and that might quite possibly be the cause of your problem.
