hanyoukimura
- Jun 19, 2011
- 382
Today I did some work on that Craftsman, cleaned the carburetor fuel tank, and replaced the diaphragm. The good news is that it fired right up. The bad news is that it has a death shake. Turns out that the crank is bent and there is a crack near one of the bolts. Very disappointing, especially after getting the wheels/handlebars back together.
Still, with little to lose besides time, I decided to try a trick I once saw. Tipping the mower on its side, I rotated the crankshaft until the bent angle was facing up, then whacked it a few (several) times with a 2.5 lb. sledgehammer. To my delight it, while not perfect, did lessen the severity of the bend, and even with a crack the engine runs without vibrating.
As for the crack, it's about 3 inches around the outer edge of the engine mount, right before the metal dips to form the channel. I'm wondering if JB Weld will work to reenforce it.
