Yep, sounds like carb cleaning time!
I presume an AGS 2160 is a ride on with a 21 Hp & a 60" cut..
In that case it has a cut off solenoin under the carb.
If the plunger does not retract when the ignition is turned on then the engine ( engine not carb ) can not get any fuel.
ok i'll try that then....thanks....johnny
