My 700 series Rider has issues!
1931ModelA
Hello All!
I could use some assistance. I have a 2014 700 series Craftsman (Husqvarna) That has been maintained to a "T".
I was merely a long, deep in thought when the old girl just quit running... not a spotter, skip or miss at all...just as if I shut down the ignition.
I shut off the PTO, went to re start & nothing! No click from the solenoid, no relay sounds....nothing.
I double checked that the PTO was off, checked the battery (12.6 volts) cleaned + - contacts on the battery & solenoid ....still nothing.
Any ideas?
Thank you,
Chris
Did you check the fuse. Depending on were the battery is located the fuse is usually clipped to the frame or taped to the wiring harness in that area.
hlw49
You should never shut the engine off with the PTO running. When you do this it makes the PTO a generator and can feed back through the wiring harness and mess things up.
Measure battery voltage between the + and the engine
Ground straps falling off will also do that .
