it will start if i jump the solenoid with screw driver whats up ?
G ghostdad Forum Newbie Joined Apr 10, 2012 Threads 1 Messages 1 Apr 10, 2012 / murray will noy start #1 it will start if i jump the solenoid with screw driver whats up ?
R redkneck Forum Newbie Joined Apr 10, 2012 Threads 1 Messages 4 Apr 10, 2012 / murray will noy start #2 Sounds like you need a solenoid, or else you are not getting 12v to the solenoid.
Carscw Lawn Pro Joined Aug 11, 2011 Threads 66 Messages 6,375 Apr 10, 2012 / murray will noy start #3 ghostdad said: it will start if i jump the solenoid with screw driver whats up ? Click to expand... Run a jumper wire from the + side of battery to the small post on the solenoid if it cranks then you have a bad wire or a safety switch Sent from my iPhone using LMF
