Okay, so I have a 2013 M2500 Murray Weedeater 41ADZ01C758. I have cleaned carb, gaskets and jets look good. Have changed fuel mixture, and lines/primer bulb and such are fine. Have also replaced with known good spark plug. Guy said it was working fine one day with no troubles, and then just wouldn't start the next. Just for the experience, I decided to dismantle entire thing, to check spark plug line and the shutoff wire inside the unit. However, I am stuck at the clutch assembly. I cannot get the piece apart. Is there a screw in there or is it supposed to pop off? Also any other ideas are welcome :thumbsup:
