LT1045wrh
- Jul 18, 2011
- 75
Hi Fellow Mowers,
RE: Murray Select, 42", 2004, BS 17.5hp, manual trans.
My new problem is when I try mowing for more than a few minutes, the mower dies. I cleaned the line, new filter, gas, and gas line. It seems as though the fuel solenoid is not remaining open because the fuel just stops flowing after the engine gets hot. Any ideas would be appreciated. Looked on YouTube and found a few ways to check the fuel solenoid, so I guess I'll do that, but sure would appreciate any incite you may have to the problem.
Spent 4 hours mowing with a reliable push mower the other day, so I'd like to get the Murray chopping again.
Thank you and mow on and on and on...,
Wendy
Wendy
