GasSniffer
If the flywheel key is damaged wouldn't it be reasonable to suspect there would be some kind of blade damage (hitting an object at high speed to shear the flywheel key)? The blade on this thing looks pretty worn and old but nothing that looks like a high speed impact. I will take a look anyway because the logic behind the timing not being right makes sense.
