gdrepairs69
- Aug 5, 2012
- 10
- 19
Murray model #461007X92A Briggs 21 hp opposed twin 461707-0116-E1 I have (spark )and good compression. Seem to have good fuel supply but just spins over without even a sputter? Could there still be a electrical problem fuse is ok and set switch ok. How to either isolate the problem to the electrical system but I have (spark) how to bypass switches brake etc. On this mower you can stand beside it and turn over the engine and get spark at the plugs. Maybe I don't understand what that black wire that goes from the magneto then to yellow wire that seems to go to all the switches doe's It want start connected or disconnected? Thank for anyones help ASAP!!!!!!!!:confused2:
