Jamilt
- Sep 21, 2014
- 1
- 4
Hello everyone! I am a new member and have a Murray Model 425007X92 that don't start. I have had no issues until now except changing the deck belt. I'm not a tech person on lawn mowers as well as computers but do have a meter and know how to measure voltage. The battery is measuring 12.45 volts and solenoid on battery side 12.44 but 0 volts on the right pole on the starter side. Yet, I have been told the solenoid is working after taking it off and bringing it to lawn mower techs. The 15 amp fuse is good but the fuse clips is showing 12.4 volts on the left clip but nothing on the right clip. I hot wired to the starter form the battery and it does turn. I do not know how to measure voltage on the on the ignition switch because it's hard to get to and i'm not sure how to take it apart. Any thoughts would be greatly appreciated.
