Model 405000x8
So one of the spindles decided to go bye bye. Well I figured I would just replace them both. Everything was working great for 2 minutes when I heard what I thought was a bad bearing. So I parked it and loosened the belt and when I checked the blade was loose. So if I tighten and spin it by hand the nut comes loose. And if I tighten it more the whole spindle won't move. I'm lost right now. Also anyone know if the washer should be flat or cupped. My thought is maybe the washer got warped.
