PJWhiskey
- Jun 16, 2020
- 1
- 5
I was mowing the yard, came to the bottom of a hill, pressed on the pedal and nothing happened. It wouldn’t go forward or reverse any longer. After some review, the tires move freely now, regardless if the parking break is on And regardless of the position of the automatic drive disconnect. I tried adjusting the clutch and the brake to no avail. the mower still pushes freely forward and back. I am Thinking I might want to replace the drive belt As it is cracked but apparently the belt is no longer available and I can’t find the belt length to see if there is a suitable replacement. Does the break have any impact on movement?
