Murray 2004-10 model 387002x92a, I can't figure out where this yellow wire
Just Don
I can't figure out where this yellow wire? Look at the picture and you'll see the seat safety switch and one yellow wire that looks like a wire connector. I looked inside the Murray where it is located and nothing. Nothing on diagrams. I can't get it to start or turn over. I checked the battery 13amps it is good. Checked solenoid it showed good, I replaced it anyway. Checked the starter and it is good. I hooked battery to it and it cranks. I did a test from the battery to the starter 12.33amps. So I think I checked every thing. Maybe the carb solenoid?
Auto Doc's
  • / Murray 2004-10 model 387002x92a, I can't figure out where this yellow wire
You read Amps or Volts?
Wire diagrams are not always 100% inclusive on some models. Other mowers may have had the same harness with additions.
Verify the 15A inline fuse is good and all connections are clean and tight.
Parts tree:
Just Don
Parts tree:
Yes I do.
First you reading volts not amps.
Second the seat switch circuit has nothing to do the cranking just affect the running as it only kills the magneto (ignition) coil. Also ignore the loose wire as the mower seat switch appears to be hardwired back to the ignition switch. Also the wiring does not indicate a carburetor fuel solenoid.
So you must trace the wiring from the battery through the fuse, ignition switch, brake switch, and PTO switch to the starter solenoid. Checking for a live circuit when the switches are all in the start positions. Noting that wire terminals can be bad at any connection point including inside the fuse holder. Also make sure you install the fuse on the right terminal of the starter solenoid Ie the one with the cable from the battery.
Auto Doc's
Yes I do.
You miss the point. What setting are you using on your meter? Providing a picture of the meter dial setting you are using would help.
Amps and Volts are not the same setting.
