P popi Member Oct 8, 2014 #1 I AM IN NEED OF A WIRE DIAGRAM FOR A B&S ENGINE 310707-0154-E1 THE KEY SWITCH IS 7 PRONG
M mechanic mark Lawn Pro Nov 16, 2014 #2 http://c.searspartsdirect.com/lis_png/PLDM/WL000408-00011.png Recheck your engine numbers as well as tractor model number, not coming up.
Flintmotorsports Well-Known Member Nov 16, 2014 #3 so all you need to do is a google search with the tractor model#s and type in wiring diagram and look to see what you can find
P popi Member Nov 17, 2014 #4 THANKS MECHANIC MARK. I FINNALY GOT THE MOWER RUNNING A SIMPLE GROUND WIRE IS ALL I NEEDED. THANK AGAIN
Flintmotorsports Well-Known Member Nov 17, 2014 #5 I am glad that this forum helped you fix your Issue
