mulching toro to one that throws clippings
poncho
I have a 36inch Toro commercial walk behind mod 30894 set up for mulching. What must be done to convert it to a mower that throws the clippings out. I know it's more that just removing the side plate. Thanks.
After removal of the baffles, would anything be needed to direct the clippings out the side opening. And to work on this, to get access to bolts etc, does one usually separate the front cutter portion of the mower from the back?
After baffles are removed nothing else is needed. It will be as factory made it. To access bolts tip mower up in front till handles touch ground. Put something heavy on handles to hold in that position.
