Mulch Cover for 917.288570
Denna
AYP no longer makes a mulch cover/plug/plate for the 917.288570 lawn tractor, nor are there any substitutions.
Does anyone know of a mulch cover that would cross reference for this model ?
Mechanic Mark,
Thanks for the quick reply.
Unfortunately, Sears only sells a mulch kit for about $70.
Having just bought a pair of G5 Gator blades, only the mulch cover needs to be replaced. Buying unneeded, lower quality blades is a waste of money.
What I'm looking for is just the mulch cover.
Since AYP no longer makes the mulch cover, a replacement will have to come from a different brand.
Does anyone know of a mulch cover that would cross reference to this 46" 2 blade mowing deck ?
Mechanic Mark,
Sears.com
Mechanic Mark,
I realize this is an old post that's been resurrected but just wanted to say that I wouldn't recommend running the G5 blades with a mulch plug. They're a high lift mulching blades best used for discharging. They throw too much air to be used with a mulch plug. You'd get a lot of blowout from the deck and likely a poor cut quality. Wavy, low-lift mulching blades such as those that come with a mulching kit are the appropriate blades to use with a discharge plug.
I realize this is an old post that's been resurrected but just wanted to say that I wouldn't recommend running the G5 blades with a mulch plug. They're a high lift mulching blades best used for discharging. They throw too much air to be used with a mulch plug. You'd get a lot of blowout from the deck and likely a poor cut quality. Wavy, low-lift mulcheimg blades such as those that come with a mulching kit are the appropriate blades to use with a discharge plug.
I absolutely agree with that. Because I have done it. Forgetting to swap my G5's for the Husqvarna mulching blades. All the mowing I did had to be recut because of the G5's. Looked good after the second cut with the correct blades.
