bravenrace
- Apr 29, 2011
- 1
- 3
Hi there. I'm new here, and hope you can help me. I have an older Toro ProLine 52 mower. The muffler needs replaced and the OEM part is about $280. It has a Kohler MV-16 engine. I would like to find a less expensive alternative to the OEM muffler. The exhaust flanges at the engine have socket head capscrews and they are so rusted that trying to turn them just strips the hex out. The pipes coming off each cylinder are pretty solid, so I've considered cutting the muffler off and buying two smaller and cheaper mufflers and attaching them to the existing pipe, but I'm concerned about noise and whether or not they will be quiet enough.
Has anyone done something similar? And if so, do the smaller mufflers muffle as well as the old single muffler? Anyone have any suggestions? The mower isn't worth putting $300 into a muffler, but I do need to keep it.
Thanks,
Jim
This is the current muffler. I would attach two new mufflers, one to each straight section of pipe coming off the engine.
Here's an example of the type of muffler I was thinking about using:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=190491674261&ssPageName=STRK:MEWAX:IT
Thanks,
Jim
![IMG_3924.jpg](http://i288.photobucket.com/albums/ll187/bravenrace/IMG_3924.jpg?t=1304100449)
