Much BETTER and longer lasting LED lights for Hustler mowers
BlazNT
  • / Much BETTER and longer lasting LED lights for Hustler mowers
Can you attach the light's power wire to the positive terminal on the starter motor or solenoid? It would be hot when the key is one and off when the key is turned off.
Tom
Wrong. Those would be off after starting. Fuel solenoid wire would be on with key and stay on till key is off.
Jefferey
yup played with that for sometime thinking that would work, used my multimeter and no go. going to just test battery for a while to see how much draw that little red LED is using after a couple weeks or so.
Pumper54
Thank you for the correction,
Tom
BlazNT
After rereading what I wrote it sounds like I am being an *****. Sorry if it came across as that I did not mean it to sound that way.
Pumper54
BlazNT,
PM sent. We are all good.
Tom
BlazNT
Glad to hear.
OUOUOU
I put some LED lights on my raptor SD and if left along for a while, they drain the battery. How do I fix, take the lights off.
Thanks
Grant
Datadave
Could you mount an on/off toggle switch in the wiring for a positive off ?
Making the lights hot with the key switch on would give you Day Time Running Lights -
which you really don't need unless your riding down the highway.
rbsmith6
This is what I used. $15 on Ebay. Power from the orange wire at the key
