MTD yardman will not crank when hot?????
jsservant
i have a mtd yardman with a 18.5 briggs twin cyl i/c engine when mower is cold it cranks right up and will run all day no problem but once it gets warmed up if you shut it off it will turn over fine but will not crank back if you let it set for 4 or 5 hours untill its cold then it will crank right up
I am at a loss on this one please help.
SeniorCitizen
I would do the following checks in this order but no guarantees for success. :biggrin:
1) check for spark at the spark plug / wire. If spark occurs proceed to step 2.
2) Remove air filter, and being careful with gasoline, put a approximately a teaspoon of gasoline directly into carburetor throat.
If it fires and attempts to run go to step 3) .
3) If it is a newer model engine with a fuel solenoid shut off valve on the carburetor, investigate that for the possibility of failure.
If step 2) was successful that's telling us there is a lack of gasoline reaching the combustion chamber for some reason.
Lawnranger
An engine needs three factors present and in the correct proportion to start and run properly - the correct air/fuel ratio (fresh, quality fuel is a must), sufficient compression (arguably 90 P.S.I. or better) and sufficient spark at the correct time. If one of these factors is missing or out of proportion, the engine will run poorly or not start/run at all. Your task is to find the missing factor by inspecting and testing the systems involved. Which factor is missing or out of proportion in your case?
If you do not know how to check for spark or perform the necessary checks and tests, youtube has some videos that will guide you through the process. Simply search youtube for what you want to test or check.
There are conditions that will prevent an engine from starting even though all three factors are correct such as a plugged muffler/exhaust, old/contaminated fuel and I am sure there are more possibilities but I will not try to list them all here so I am going on the assumption that one of the factors is missing and that all other components are functioning properly.
You will need a compression gauge to test compression so if you do not have one or do not have access to one you will need to take it to someone who can test it for you. You will also need a spark checker which can be made from an old, working spark plug by clipping off the side electrode, connecting the plug to the lead and resting the metal hex of the spark plug on the metal part of the engine but this is not always as easy as it seems as many engines have plastic shrouds and other obstacles in the way. My method of testing for lack of fuel is to spray a shot of carburetor cleaner directly into the carburetor (air filter removed) and try to start the engine. If the engine starts and runs for a second or two and then dies you most likely have a fuel delivery problem.
Perform the necessary tests, report back with your findings and you will receive further advice based on your answers.
jsservant
ok on this one the coil was heating up and was not working right when hot
thanks everyone
Lawnranger
Good job! Thanks for the reply telling us what ultimately fixed the problem.
