MTD yardman hydrostatic trans 42" deck. Ive been having trouble getting my Kohler command 16hp to turn over. Battery is fully charged at 12.7 volts, getting 12v into the starter solenoid, ignition connection to solenoid is ok and making it click but no power going to starter, tried bypassing the solenoid by jumping and still nothing. I also used jumper cables to connect battery directly to starter and still nothing. Is it possible that both the starter and solenoid could go out simultaneously? Could the motor have locked up? What's the best way to test it before I start buying parts or another mower?
