I have a MTD Yard Machines 14HP Riding Mower I bought in Fall of 2002. I believe it is a Model 660F, exact model is 134AM660F062. Last fall I replaced all 3 of the belts on it because when engaging the drive it was starting to slip quite a bit. At least one of the belts was in real bad condition. The book that came with it had some pretty good instructions, and after a weekend, I was able to replace all 3 belts and have everything back together. Everything works well right now, except for one thing. When I start up the mower, without engaging either the drive nor the blades, the engine pulley in the front will start to heat up fairly quickly. Last fall before I put it away, I drove it over to the storage shed and the pulley was so hot, that the new belt was starting to smoke a bit. I tried to loosen and re-tighten the engine pulley bolt on the bottom, thinking that it maybe too tight, but it is still heating up. The belts don't seem to be too tight and the pulley does turn. Any ideas? I thought I'd try this forum first, and then if I'm not having any luck, I'll be taking it to a shop. Thanks!
