MTD Deck Height Adjustment
Freddie21
Using a Troy-Bilt 13AN77TG766 as an example, is there any way of adjusting the height of the deck? These are machines with a manual PTO and the height adjustment arm on the fender. The numbers on the fender show from 1-5. After doing the deck level and front\back adjustments, the blade tips will be around 2.5' with the deck set in the #4 position. This cuts short.
