Hello,
I have a Yard Machine 21" 3 in 1 650 series 6.5 hp that will start, but has low power.
It's not to the point where it will cut off, but the power is too low to cut. I've also
noticed that when I tilt the mower forward at a 45 degree angle to power increases
to 90% normal. As soon as I level it off the power immediately decreases. So far
I've tried cleaning the carburetor by removing the bowl. There was a little dust
present, but even after the cleaning the problem persist. I also sprayed carburetor
fluid in the passages as well as changed the spark plug and filter. Has anyone got
a clue what's causing the problem??
Thanks,
Troy
Thanks,
Troy
