Can I be cheeky and ask a technical question or two please?
My mechanical experience doesn`t lie in ride-on mowers, so have no idea how much end-float and lateral play is acceptable in the half-shafts of a transaxle.It is currently out of the mower and worked fine but there seems to be a lot of play in the aforementioned components.Is this normal?
It`s covered in old oil but this may have previously dripped down from the engine.How easy are they to test out of the mower and is it true that they can be topped up if low on oil....a mower mechanic I spoke with years ago claimed to have done this...if my memory serves me right.
I removed the bolts at end of half-shafts and they smell of hypoid gear oil...what grade do they run on please?
It`s the free-play in the half-shafts which is my main concern.
Thanks in anticipation for any advice
Regards
Blighty
Regards
Blighty
