Grumpy1969
- Jul 4, 2024
- 2
Cranks and runs great until I run into high grass and engine dies...... usually after about 45 minutes or so. Then when you try to crank it.. the engine acts like the piston is swollen and will not turn over. If you raise the mower.... you can move the blade back and forth but can not crank with rope will not turn over..... really afraid I'll brake the rope..... not sure if crank shaft is going bad or possibility of the safety on the handle is not releasing to crank.
