Engine MTD 1993 Briggs engine how to remove old shaft pin on starter recoil?
gdrepairs69
Please HELP MTD 1993 Briggs engine how to remove old shaft pin on starter recoil?
]Briggs engine how to, what do you use to remove old shaft pin in the center on starter recoil? See picture attachment.
It uses a dowel pin to secure.
The picture shows the bottom side. Remove the starter rope if its not already off. Let starter spin back so not tension. Turn starter over. Remove sticker on top.
Using a punch tap dowl out. Use a piece of pipe or a spacer to rest bottom part on.
Once dowl is out the plate, dog pawls and pulley will come off.
Why do you need to take apart?
