Ooops, it's a MS460... Not a 4601.
The customer dropped this off and said it had been sitting a while and just wanted me to check it out. Said he hadn't even tried to start it. So I pulled the plug, which looked fine. Peaked at the cylinder walls, they were fine. Removed the muffler and checked the screen and the cylinder walls. (but didn't really look at the piston) Everything looked good. So I put some fresh fuel in it and pulled on it a few times and it fired up and ran. Ran it for a couple of minutes, and it was good. It was oiling the chain, so I set it aside and called the customer to pick it up.
When he got there, It fired right up, but within about 30 seconds, it fell flat on it's face. Like it was out of fuel, or not getting any.
I pulled and pulled and got nothing. Checked spark, which was good. Then did a compression test. It was below 90.
Pulled the muffler again, and this time, I had to rotate the piston up then back down, I noticed the edge of the piston was scarred bad. But the cylinder walls were still not bad.
Is this even possible? Because I've never seen this. It's usually the cylinder walls that are scarred.
