THis is an old post but just for the record, the problem still exists. I've tried different blades. The mowing deck has a relatively small cavity which may or may not have anything to do with it but it throws debris out all around. More debris comes out the discharge chute, but some blows out all around. This was the case with the original factory blades and it continues to be the case. I chose this model because it was advertised as being better suited for pulling loads and I needed to be able to pull my chipnvac. The old rider, which I think was a Craftsman LT1000, had very little blowout and quite frankly was easier to use. It handled better and it seemed that the mowing deck tracked better right behind the front wheels. That made it possible to trim closer. The new machine beats to crap out of you while you are on it. If it weren't for the supposedly more robust rear end I wouldn't have a lot of good to say about it.
