excalibur2
- Nov 11, 2016
- 1
- 22
Hello all, Jim from CT here. Been banging my head against the wall for weeks now trying to get this mower to turn over. It is a craftsman model 536.270320 mid engine rider. Turn the key to starting position and nothing happens, not even a click. Installed new solenoid, swapped out starter from another rider which I know is good, replaced safety switch under the seat, checked entire wire harness and no cuts or breaks, tested both pto safety switch and the brake safety switch with an ohm meter, both have continuity. I don't know anything else I could check. Also put new fuse in as well as another ignition switch. What's left??? Is this solenoid wired correctly? Can the black wire from the harness share the same ground as the neg battery terminal as shown below? Red wire on right goes to starter, red wire on left goes to pos battery terminal.
