mower wont start
ffsmith
I just replaced the aluminum flywheel starter gear on my 15.5 hp briggs engine craftsman mower. It will spin like it did when it was new but will not start. I replaced the coil, gapped it right, but it will not start. Thought might be flywheel was put on incorrect but cant go but one way with the flywheel key. What now????? Thanks Dustin
reynoldston
what is your coil air gap. Myself I use a peace of paper for a feeler gauge.
Briana
Hey there - WELCOME to LMF! :smile:
I moved your thread to the Small Engine & Mower Repair Forum.
originalswampfox
Be sure the kill wire from the coil hasn't gotten grounded, that's my usual mistake.
reddragon
check your spark while cranking to see if thats it.....
jc56
Reddragon is right.First you've got to see if you have spark...if not...I would probably re-visit the coil.
mowerguy
id check the valves. if they are just the slightest bit off it will not start
If you had the flywheel off to change the ring gear and didn't get the flywheel torqued properly it could of sheared the flywheel key when you tried to start it. I have seen then offset as much as 180 degrees (half turn) from where it should be.
