Mower won't start.
Dalejm
I am new here and Thank you for accepting in to your world. I have '03 721D Grasshopper mower. It has a D722 E engine,I have been having an issue with it starting about a month ago, and now it won't start. I have changed all fuel filters, new starter and battery and ignition switch. Plz help and thank you in advance.
reynoldston
Just why are you just replacing parts? You started with a fuel filter then went to the electrical. So dose it turn over with starter? Stop jumping all over the place and get yourself a service manual. If its electrical you will need a wiring diagram. It sounds like it would be cheaper for you to take this mower to someone who knows what they are doing.
bennieboy
Hi, I'm having trouble with my Ferris not starting. My mower don't do anything, turnover, nothing. Does your engine spin or is everything dead? Have you checked all the safety switches to see if they are good? If the engine is spinning it could be the magneto or bad plug. Just a guess!
