jplaugher1
- Oct 18, 2011
- 1
- 1
I try to start the mower, just get clicking noise. I replace battery, solenoid, If I jump the mower with my car it starts. If I remove starter and test it by grounding and leaving hot wire connect, the starter does run when it's not trying to turn the crank of the engine. Should I replace the starter or all the wiring from the battery to the starter? any help would be appreciated. I can get lawn mowed if I jump with the car or attach my battery charger.
Thanks,
Jim
Thanks,
Jim
