Mower won't move
Mr.Guy
Hi!
I have a 60" Dixie Chopper Flatlander that will not move. It has been sitting for quite some time. I need to move it so that i can get it running again. Is there any bypass or something I can unlock to get the tires to move freely?
Thanks!
WELCOME to these Forums.....
The Silver Eagle has this procedure... : "Do not exceed a speed of 2 mph when
moving the mower without power.
In order to transport the mower without power, you
must first release the hydraulic pressure by using the
bypass valve located on each pump. Lift the mower
seat to gain access to the pump valves. The valves are
a 5/8" hex head located on the valve block of each of
the pumps, with a cross hole through it. Loosen the
bypass valve on each pump, three turns counterclockwise.
Move the mower. Tighten the bypass valve on
each pump, three turns clockwise."
Take care and post back if you have further problems... :smile:KennyV
