[email protected]
- Feb 11, 2013
- 37
My mower will not prime and I have replaced the diaphram gasket> not sure what to do :confused2:
Please post the model number info for the engine so we can see what you are looking at.
The model and serial number of the mower doesn't tell me what engine you have. The numbers I am looking for are stamped into the blower housing either above the spark plug, or on the flap above the muffler if briggs, may be some other location with another engine make.
Briggs engines will say model, type, code above the information. if the engine have a plastic cover over the engine it can be hard to see the numbers above the spark plug. They are located about half way between the top and bottom of the cover. Will look like xxxxxx xxxx xx xxxxxxxxx where the X is a number or letter.
