logert gogert
- Jan 11, 2020
- Threads
- 16
- 547
Hey, I recently straight piped my mower ( don't ask why ) and for the first couple days it was fine, but then I noticed that one day I went to go move it in the shed, I started it up let it warm up for about a couple minutes ( like I always do ) without revving up at all, the I drove it over to the shed and since I have a foot throttle if you let off the gas it does it quickly, so I let off the gas and it turned off once it got to idle speed.
I went to start it up again, started up perfectly like it always does, started to drive and once again let off and it did it again. Started it up again and this time slowly let off the gas and it did NOT turn off when you let off the throttle , parked it and went inside.
The next day I went out to go check it out, did the same thing once again, but still if you let off fast it cuts off, let off slow it does not.
Then I put the muffler back on, and it would not cut off wether you let off slow or fast.
Any body know why it would cut off straight piped ?
The motor runs much easier straight piped besides that one issue, and I would like to keep it straight piped,
Please help
Please help
