Mower Surges.. Engine or Something else?
Ok thanks I will leave this to 7394...... Something is definitally putting that engine in a bind. He is better than me on those drive trains.......
rubantin
One more thing. When I do a turn it stops doing it!?!?
When you turn it is putting left or right pressure on the rear end. Hence the internals are moving inside causing a bind..
rubantin
It doesn't stop.. rather it stops doing the pulsating and runs smooth
7394
Sorry can't be of more help. I just know about that transaxle, since I ended up swapping it out to a Peerless 6 speed. Then later sold the mower.
hrdman2luv
I'm guessing (on 1/2 cup of coffee so far) that it's the drive belt.
rubantin
Good idea. When I get a chance, I'll put some dressing on it too see if that makes a difference
rubantin
Put some dressing on the Belt and fine-tune the carburetor slightly rich. Motor doesn't surge but the thing still acts like a pulsating bucking bronco
hrdman2luv
Is your drive belt loose? Is it on correctly?
I just changed a drive belt two days ago, It was only being held on by the guide. Slip on, slip off. But the guide would keep it from falling down all the way to the other deck belt.
