O Omahatiger Forum Newbie Joined Sep 13, 2016 Messages 4 Sep 13, 2016 #1 I have a Walker 26 HP Efi. When the grass hopper is down it will stall when you hit a bump. If you raise it and drop it back down it will immediately resume operation as normal.
M mechanic mark Lawn Pro Community Leader Joined Jul 15, 2013 Messages 7,500 Sep 13, 2016 #2 check all wiring by hand for loose connections, including ground straps & cables from engine to chassis.
