11A-A2SD791
CMXGMAM2703840
Mower starts fine when cold but after I shut it off, it will not start again until extremely cold.
Coil is good, carb is new, compression is good.
I tested the choke with my torch, the spring does move the linkeage enough to close the choke plate.
I think I have the choke set up correctly (see below).
Any ideas?
Thanks
CMXGMAM2703840
Any ideas?
Thanks
