Mower Starting Issue
BoiseHM
I have a craftsman mower with a Model #143986700 - 6.75hp Craftsman Engine. It starts for a few seconds then quits, i spray a little carb cleaner while its running and it will keep running. I cleaned the carb and it still has this problem.
Not my mower in pic but looks just like it.
thanks for your help...
ash3001
Did you take the Carb apart fully and cleaned out all ports and/or needle valve if it has a float?
also did you use starter fluid to get it to kick over or just primed it ?
BoiseHM
no, not yet... i used the red primer to get it to start then when it started to die down i sprayed a little carb cleaner in the carb...
mikey11
definitely sounds like a fuel mixture/carb problem
does it have a manual or automatic choke?
BoiseHM
kicked to to curb on CL... thx for the help...:thumbsup:
