I bought an old Craftsman LTX1000 on Craigslist. When running, it cuts well, but then it dies. Seems like it’s running out of gas, but there is still a little in the tank. When I refill, it starts, but then stalls when I have it on fast and try to mow. It will idle on choke. It will idle on low, and also drive slowly. As soon as I put it on fast or engage, it stalls. If I wait a day then start it back up, it will run. Any suggestions?
Should I use some carb cleaner?
Has a new spark plug and air filter.
Side note, when I checked the oil, dipstick was hot. Oil is nice and clean with new oil filter. Not sure if it is any hotter than it should be.
Thoughts?
Thoughts?
