William Thomson
- Nov 18, 2015
- 1
- 1
Hie..
Through this article I will suggest you the basic steps of repairing Mower-
You should disconnect the spark plug lawnmower before you start with the repair so that their are no chances of the engine starting. It is good to wear working gloves, because engines have sharp blades and dirt which can give you an infection. For Eye protection wear glasses so that gasoline and dirt do not end up in your eye.
I hope you are comfortable with this tip. :smile:
