Engine Mower quits
Chrismatthewssr
Hello guys, I have an older Kubota garden tractor G2000, you can be cutting grass for about 15 minutes and it just cuts off, no spit, no sputter, just like you cut the key off, after 10 to 15 mins it will start back up and go for another 15 mins of so and then off again, any help would be great,
Thanks
Chris Sr.
Next time it happens check to see if you have spark. Sounds to me like your coil is going bad.
LCBINC
Thanks
Chris Sr.
I had the same problem with my TG1860G. The problem turn out to be the carburetor solenoid.
