Mower not running fast enough when PTO engaged
Unsworth
I serviced my Simplicity tractor for the season and used it 3 - 4 times but now the mower will not run at full speed when I try to mow. When I try to mow the engine falters. The tractor without the mower engaged drives fine. I am stumped. Anybody have this happen to them and might know what the problem is?
Twins running on one cylinder
debris jambed around the blade spindles
bad spindle bearings
bad idler pulleys
short in electric pto's putting excessive electrical load on engine.
partially blocked fuel lines
faulty governors
Bad fuel pump
bad idler pulleys
faulty governors
Bad fuel pump
Thanks for the suggestions. I will look into it.
