Total newbie here with likely a newbie question. Thanks for having me.
I have a 2010 LTX1042 that I don't know much more about than how to cut my grass with it. The mower came with the house, so this is my 4th season cutting with it. It has ALWAYS cut too low.
The highest setting gives me about a 3-3 1/4" cut, and the lowest setting bottoms out on the "outrigger" wheel before you even get there...it actually won't even go to the lowest settings.
When I look under the mower, it looks like the deck is as high as it will go, as there is a steel extension attached to the top of the deck that restricts it from going any higher.
What could be causing this low cutting height? Could it be a suspension issue possibly?
I'm happy to provide pics if that will help, but wanted to get this posted as it is driving me nuts! Thanks in advance!
