Mower engine wont start
bvdave
Hello, so I am having a issue with my Husqvarna mower
My battery died the end of last season so I got a new one in the spring, changed out for the old one, mower started up just fine so I went to go cut my grass and got about 60 feet when the wheels stopped turning. turns out a pulley locked up and the belt grinded it apart then fell off. so I pushed it back to the garage, ordered in a new pulley, and replaced it.
after replacing the pulley the mower wouldn't turn on, turn the key and nothing, engine wont even try and turn over, no clicking, nothing. if I pull the switch the engage the blades I hear a clunking noise so power is getting somewhere (it wont do it without the battery connected or key in) so I talked to the small engine repair place in the next town over and they tested my battery and deemed it perfect. they then suggested I may have a bad solenoid, so I bought a new one and changed it out. no change, still nothing whatsoever happens when I turn the key.
any suggestions where I could start my troubleshooting? I cant even bring the mower in anywhere because I loaned my trailer to my mother for a few weeks while she went up north, so I have no way to move it for some time, and could really use to cut my grass before farmers mistake it for a field growing hay..
no idea how old the mower is.. the people who sold me the house just left it behind as part of the sale agreement.
any suggestions would be greatly appreciated, please use layman terms if possible as I am very new to this (before moving here just over a year ago I had only ever needed a push mower so any kind of small engine repair let alone riding mowers in general are very new to me)
cpurvis
Did the pulley/belt fiasco take out one of the interlock switches or wiring?
bvdave
no, the mower is set to off as the engine doesn't start with it on normally. (I learned that after much confusion when I first got it)
*saw you edited it. but I wouldnt say stupid question. I am 90% convinced its not working because of something stupid I did that will turn out into a very simple "hey moron.. do this" type fix
bvdave
I dont think so, at least nothing that I saw... and if it did I would assume it would have cut the engine right away no?
but im going to go take another look around the area again and take a look for that specifically thanks!
cpurvis
Can you try using jumper cables and go direct to the the starter terminal? If that won't make it crank, your starter is the suspect. If it will crank, it about has to be a problem with an interlock switch or the wiring to them.
There are smarter people than me by far who are on this site. ILengine, bertsmobile1, rivets, just to name a few. They'll need the model number for your engine and maybe the tractor, too, but it's just about guaranteed that one of them has seen this problem before.
bvdave
you mean use jumpers to try and go from the battery to the solenoid terminals? or is starter terminal something else?
bvdave
attahced model number and a shot of the pulley that was replaced... dont know if it will help but there it is :)
cpurvis
One of the big solenoid cables goes directly to the starter. You can touch either end of this cable. In fact, you only need to use ONE of the two cables in a set of jumper cables if you use the battery in the tractor. One end goes to the positive battery terminal and the other end you touch to either end of the starter cable. Be advised: This is going to SPARK! DO NOT clamp the jumper cable on the starter cable; just touch it to see if the engine starts to turn over. We are bypassing everything at this point, just to test the starter.
Batteries put out a lot of amperage! Don't touch the jumper cable to any metal portion of the frame or engine or that will be a spark show and you could get burned. In fact, if you don't have any experience with jumper cables, it's best to let someone who does do this procedure. Would hate to hear that you got hurt trying this.
Common problem when a mower dies while mowing.
Is the blade switch turned off ?
Yes we have all done it.
